hows that ford going i can give some help if you still need it
does this mean exactly what is says?
Attachment 46766
should this be maxed out to get rid of some more torque management?
Never had a reason to change that table. I just disable the trans torque management drop down boxes.
Russ Kemp
what exactly here are you disabling? master and shift? if those two are disabled does that disable all torque management for the trans making it not necessary to mess with the upshift/downshift torque reduction?
also, what is truncation?
Attachment 46773
Yes, just need to disable the master & shift drop down boxes. The truncation is also some type of torque management, but it is already disabled in your tune.
Russ Kemp
im guessing that the upshift and downshift pressure, desired upshift time, and clutch fill time will all need to be modified after disabling torque management?
Attachment 46837
any threads or ideas on where to start modifying these tables so i dont kill my tranny?
I just add 20 psi to the entire upshift pressure tables, no need to change the downshift pressure tables. Then fine tune your upshift tables by adding or subtracting 5 psi at a time until you get the shift firmness you like. Leave the desired upshift & clutch fill time tables stock.
Russ Kemp
is there a way to make a histo that mimics this table?
Attachment 46840
seems like i would need one to set part throttle and wot firmness separately. id like a firmer shift part throttle and not neck snapping but wot can can be harder.
or will the table just work itself out like that naturally but adjusting it the way you described across the board?
yeah thats what i figured after thinking about it for a while. guess ill have to try this out soon and see how it feels.
anything specific for the trans i should be logging?
another question, how does disabling the master torque management affect acceleration before/after shifting? does it put more power to the ground? i cant find anything about non-shifting (normal driving/accel/decel) transmission pressure but since theres 2 torque reduction settings, master and shift, im assuming 2 different things are happen, one is shifting and the other is everything other than shifting.
am i close or way off?
