Originally Posted by
Higgs Boson
Yes, it does hold commanded timing (for the most part) even though it shows retard, however, my Hi and Lo tables are the same right now, not sure if that is why. One issue I noticed while under the car, a header primary is literally resting against my "oil cooler." I guess it isn't affecting anything regarding knock since there is none at regular VE values.
I only am getting this phantom retard over 1.0 Pressure Ratio......the more I obsess over it, the more I think it is a fail safe of sorts against failing fuel pressures. It will be a week or so and I will have a second fuel pump to mount on the tank and we will find out for sure. Until then, I am done with it.....rev limiter set to 3500.
BTW, i have a 37% ethanol mix in there now and it carries slightly higher before nosediving. I am considering running it out of fuel and filling up with MS103 or the like and seeing if that will allow me to get to 7K, although I don't want to use race gas (or meth), the whole point of this build is E85.
regular knock sensor, I haven't missed any spark tables.
