Uploaded my stock 2014 Auto 5.0 read to the repository.
Great support Eric, noticed however catalyst monitor and o2 response rate test parameters and stall speed under transmission parameters are missing.
Super excited for this release! Thanks for all the hard work from Eric and the rest of the folks at HPT! :worship:
New beta up that will allow you to run 2.24 & 2.25 side by side at the same time, so you can use the stable version on most applications and beta for the 2011+
I can verify that now.
I did have to remove the Beta and reinstall 2.24 then I was able to load the Beta with out overwritting.
Now have both Current and Beta releases working side by side.
Good job!
Bill, the new beta that allows running side by side with 2.24, was that made available to everyone who had a beta link?
Yes
You need to update
There's a party up in here today!
Update.... I did not drop the ball on this actually.
Proof:
http://www.brooksspeed.com/hptuners/StallSpeed.JPG
That parameter does not exist in the 14 code.
Is anyone having problems using the compare calibrations function?
That's still in development.
I'll disable it in the beta until its ready.
Also in case anyone has a similar problem. I had a 14 mustang freak out after a completed flash and would not start/crank. I reflashed and same thing. I had to disconnect the Battery for a few min and then Reflashed again and all was well.
Great job guys!
Rick, if that happens again, try using VCM Scanner to clear the DTC's. We may have to incorporate that into the write process.
Will try that Keith thanks. Before anyone Panics this has also happened to me using the "other" software after Writing a full tune.
Can i just switch users and download the 2.25 and leave the 2.24 on the first user?
you can install both at the same time.
