Nice!!! What plugs and gap are you using?
have been experimenting with different plugs but primarily the ngk 2668 ( bkr8eix i think) gaped at .025 tried the ruthenium but the coldest they come are 7s and they were trashed after 2 months use.
Awesome thank you. I'll grab a set asap to try. Have you played with plug gap to see the largest you can run before blow out?
I'm running 1 step colder plugs rn, and it's not perfect. I'll put the 7EIX's back in to see the differences. A lot of conflicting info online about plugs on stock turbos, different stages of tunes, and ethanol blends. I've always used stock plugs on stock turbo cars anyways, so was just kind of experimenting as usual.
Appreciate the info.
The plug reading looked really good on the 8's, but she's definitely happier on the BKR7EIX's for cold starting, and cruise/idle conditions.
Frikkin sweet Avant man 😍 I have the same thing in black, but mine is slowwwww haha. K04 maybe one day
Managed to get the fuel system stable enough to allow for about 3.3Gal of E85 to a tank (roughly E30) some impressive results for sure :)
Attachment 107857
Attachment 107858
Attachment 107859
Attachment 107860
at least till we get next dyno
got some runs in this morning, moving pretty good for 4400 lb station wagon
https://i.imgur.com/ITjTNXx.png
So doing some upgrades so here is my best run with the current set up.
https://i.imgur.com/VGdyhhf.png
pulling consistent 12.3s with the the k04 and WPT tune
https://i.imgur.com/NT4iYHY.png
