ok i added the new stuff for OS's 12610055, 12619549, 12625310 and 12629314. If you have another OS please email support.
Should be in the next beta. They are under Engine Diag, Airflow.
Chris...
Chris...
probably be available early next week, email support and Bill will update you when its available.
how do i check the os its been a while my cars been broken?
or open one of your .hpt files and look under Calibration Details.
BTW... this should hurry up, lol.
also added to the following Saab OS's:
55560288
55563997
55566297
55570272
55571827
I'm also on the list.
Thanks Chris
I sent an e-mail to "support", so I assume I am on the list as well.
Ditto.
i'll celebrate when i know it works ;)
wonder what the next issue will be!!! :rolleyes:
Lol aint it the truth!
next want will prolly be fuel injection pressure control hahah
Quick question about what's coming. Yesterday an owner of a retuned GMPP GXP says his HPT is showing max boost of 23psi while a gauge is showing 27. Does 2.23 Beta show above 23psi, and if not, will the NEW bate show over 23 psi on the LNFs?
I think it was mentioned before that its a pid limitation, only outputs 23psi max.
Maybe if we can get pid for the tmap sensor it will output higher readings, Chris have you seen that tmap pid in there?
pid limitation causes the factory gauge to be only accurate to 23 psi.
and we want fuel pressure tables released in the next two months please with corona on top!
