I want to revive this. Has anyone used Optimal Welding for tuning? How was the tune?
From posts I?ve seen some like his tuning, those with 2019?s have had some issues with his tuning. Don?t know if he has much in the way of high altitude tuning. His location is much the same as my home base, about 3000 foot
I had no issue with his tune a lot of time for sotf on hptuners and they are really good
Yeah Jim, this is my worry about altitude. I don't think a lot of people realize how hard it can be to get a clean tune up here with mods. It still runs sorta clean when I go back to stock form, but it seems as soon as I tweak any little thing, smoke appears. Very time consuming for sure. I am probably tweaking too much at a time as I am impatient and lack time to get an optimal tune.
Ive just purchased Optimal weldings 6 tune with switch and currently waiting on switch via mail. I did give him the stock tune and got the new tune in the same day and had asked him if i could load the tune without the switch and he said yes, but wouldnt know what tune it would be on. So i loaded the tune and fired it up with no problem untill i went to drive it and wouldnt shift out of first... the tune is definately more powerful and better throttle response but wont shift. So i loaded the stock tune back in and no problems, drove great. I had emailed him about it and he said it might be on valet mode and that i should just wait till i get the switch installed, however i never got a "valet" mode as one of the 6 tunes. supposedly 12v, 12v race, stock, race, tow, street. Im still optomistic as the tune was nicer than stock just off free revs and that first gear power. This truck has almost half million miles and the rpms would hang pretty bad when revved up and with the Optimal welding tune it would rev quick and fall just as quick, stock would hang in the mid rpm range and take a couple seconds to idle down. Ill be getting the switch in a few days and well see how it all works out.
Noah, I think that a big part of your smoke issue could be the BMS injectors you have installed. I've seen before where you stated that the smoke didn't really start until after the injectors. A really hi quality 50hp injector shouldn't increase smoke output at all.
I agree. It did ok with smoke in stock firm, but rattles. As I tune the rattle out the smoke gets worse. Still trying to figure out. I'm taking a step back and slowly modifying the stock tune to see where smoke starts appearing.
The BMS 50's, do you know what spray angle they are? are they 126 or 143? I would start with different injectors most likely.
Sac 128 degree 50hp bms. I did verify on dodge vin check that this is the 325/600 ho motor. This should be the correct injector although i know stock is a 126 degree.
Attachment 101113
Looks like 04.5 + to me.
I've had one customer that had a really consistent smoke issue and it ended up being wrong spray pattern. Not saying that's the issue, but after tons and tons of tuning revisions it should be better..lol On thing you could try, would be to take that old tune of mine that you had in it for a while. And put a more stock duration table in it and see if it runs cleans. On the timing table, just drop max timing down to like 24* but don't adjust the mid range, jsut the vary top and see what happens.
On the timing table in the area of concern, likely 20-75mm3 I'm assuming. Put timing to a static -2 (2* ATDC) Then do a quick blend to smooth it. See where that gets you for smoke output. If it's clean, start adding timing until you start to haze and go from there.
Dom, what do you see here in my log file that would cause high amounts of black smoke in the spiked TPS areas? The smoke comes on strong and gets to be less as turbo spools towards the peak of TPS.
Tune is attached as well for reference. I made the changes you suggested in the smoke areas (20-75mm3) (650 to 1800 rpm).
what's your wastegate spring? I had issues when I went to an external gate. I would build a lot of drive pressure while spooling and it would push the gate open before I made good boost.
No worries there. It wont start open until 32 to 35 psi, however I have it closed off with a boost elbow for testing purposes. I never hit 35psi at this altitude and my mild tuning. I am normally hitting around 30 psi getting on the freeway up mild hills. Ill hit 40 at sea level with no smoke whatsoever. From a dead stop, it definitely lags though at altitude.
For these reasons, I dont really feel the injectors are an issue. I would guess they would haze and smoke some at sea level if they were faulty or an incorrect spray pattern.
Adding boost won't do anything for the opening pressure if your drive pressure exceeds boost pressure by more than the spring pressure. For Example. I had a 15psi spring in mine, and had a manual boost controller to adjust pressure on the gate as well. But when spooling my drive pressure would go up to 35-45 while boost was still like 10.. so it would push the gate open and be a smokey mess. You don't have enough fuel to worry about having a gate anyhow. I would remove the gate and block the port and see what happens.
