Sorry I do not have that.
Damned, Eric, have you delete the 132mm TB data on the post ?
I wish I had saved it in case I come across a job tuning one.
I have it :rolleyes:, any one wanna it please send pm I'm afraid if I post here Eric ill be mad
answer from Whipple :
"Sorry we don't have this data its Ford data a subcontractor at Ford does thecalibrations and we don't have access to it either .
Thanks "
what a joke...
I was asked to remove it. Sorry.
I guess this means there's no chance of you posting their entire tune file then?
That's actually what I really wanted to see also. Besides just being curious at all the little things.
I'm sure it's changed as it's a Ford FRPP template tune which means even though no one can technically change the tune, they do have access to turning safety's on and off such as if it hits a injector duty cycle limit, cht limit, knock limit and so on - it puts the engine into a partial REP and if the driver keeps trying to push it - it will kill the engine all together until the key is cycled... This also gives the shop basic access to gear ratio and tire sizes, but absolutely no way to adjust the tune to fix all of the problems with it...
Any update on this? I'm looking for a 15-17 F150 Whipple read.
While I've not seen an F-150 specific tune, if you're looking for 132mm TB data, this post has a tune in it https://www.hptuners.com/forum/showt...ighlight=132mm
Unless it was removed, I posted a whipple f150 tune for a 15'... It was a stock TB though... (OE Whipple is the F150/Latest Whipple is Big TB Mustang)
Forewarning to everyone - do not copy this OS - it has things in the background to kill the OBD data line, so you can't log it :/ If someone has a newer one - the latest whipple cals are supposed to have this removed...
GHuggins, I have a 2014 with the 2.9 front inlet and 132 TB and I have been looking at the TB info in my tune vs. the one you posted and they are way different. Any idea why or which is actually correct, or is there a difference between the s197 132 TB and the s550 132 TB? Here is a copy of my tune.
Thx.
