No freeze frame data.
The only codes are a P0103 & a transmission temp out of range (wire is not connected to PCM)
And a pending P1514
I see Maf data in the channels of my scanner so they are active so data is coming through so I think the MAF wiring is fine. I wired th harness in wire by wire. Confirmed each connection. With the stock tune it runs flawlessly.
I've set up my graph to show Maf data, and it is showing in the graph vs Timeline, but NOT in the Maf Error histogram.
I must have something wrong. I followed a Youtube video precisely setting it up. Similar to my WB error hist. I've got the cell labels across, and I am getting current data in the first cell only, no matter what running RPM the other cells do not populate.
https://s6.postimg.org/e8w3ian4x/maf-chart.jpg
