How do you post up channel configs, logs or tunes?
If you have the 2010 computer it would work but the early ones have the wrong com speeds. Hptuners has a listing for the aem can wideband and list exactly this as the main issue
Apprectiate it. So to tune older cars I'll have to buy another wideband?
I think it's a signal interference
This method does not work, yet. The CAN connection of the AEM 30-0334 is through the OBDII connector. And, that woks with pretty much all CAN based ECUs. The CAN wires on the prolink are a separate bus. My understanding is that they will eventually be able to read the 30-0300/0310 CAN data. This will be the best possible interface. Until then, if you have the 30-0300 or 0310, you can have them reflashed to work with the OBDII port.
Well no it still has a 0-5v signal port
I got a little frustrated and impatient trying to make it work with no success. I removed the pro link and reconnected the obd2 port to the gauge. Got everything set up in the scanner no problem, but of course I run into other small problems. Right now I have an exhaust clamp in the tailpipe for the wideband. Just sitting at idle I have a commanded afr of 14.68 but the gauge and scanner are showing me a mixture so lean that it tops out the gauge at 29.4 afr and occasionally dips down to maybe 24 ish. Going for a quick drive the gauge will be a couple of points higher than the commanded afr, but my fuel trims are within a couple percent so it seems I may be getting too much reversion or something with the sensor in the tailpipe.
the sensor in the tailpipe is only good for WOT, normal driving its not gonna give an accurate reading. its best to use the o2 slot for tuning.
maybe I connected mine wrong, this is how I did mine. I have 2000 camaro z28,
I cut the OBD2 port off the wire that has the brown and green and used those colors. I have the pro link blue wire connected to the green wire and brown wire connected to the black wire. they're soldered together. One going to the gauge, pro link end going to the MPVI2 and other end going to a power adapter that gives power to the guage from the cigarette lighter. everything works, gauge reading AFR with no problem but I do all the steps, and I did it 100 times the list doesn't exactly show AEM 30-0334 but it shows all the others AEM, so I tried all of them and do a scan and it will just disappear.
I've talked to others that is using the AEM 30-0334 with CANBUS and it works so I dunno what im doing wrong here.
when the aem comes across the can it is read as something like WB LAMBDA B1.
the way i described requires pinning a unpinned position on the back of the aem gauge where the gauge itself send the older versions 0-5v signal out to any datalogging device that can accept that voltage range.
