Thanks!
So I was going through and making the changes that SiriusC1024 had on his last file to the pull of mine and there are some areas that will not accept any changes or the axis is different so it shows that there is a difference in the area.
Attachment 139408
Attachment 139409
Attachment 139410
Any tips?
Here is the file.
Also, are the OS enhancements recommended?
Thanks in advance!
Yeah I didn't change those settings in the tune. Compare the original to mine of the 22 Explorer ST to see what I did. That's why I was saying be careful. There's a lot of difference between your vehicle and the ST.
If you'd like upload here your stock file and I'll go through it.
Almost forgot.
Not sure if it matters, but the platinum has 3.31 final drive gears vs. the ST's 3.58
Cam angle correction.
What exactly did you do? I put the same changes STv4 into the tune I gave you.
You don't really need to mess with the transmission side unless there's a problem.
Those differences were in the column axis values for rpm.
Ive got a 20 plati aswell. And loaded sirius tune he did for it. However, going thru it there are a few differences that im just unsure of. on the distance table. 3k rpm is there twice? on my stock file it has 2500 there. id think its a problem if 2 tables are showing different data for the same rpm range? And under intake valve opening. at the 1k rpm the change is seemingly alot, -50 to -35. but 1200rpm+ on both files stay the same? these would both be in airflow - variable camshaft
You're right about the 3000rpm double columns. On that Platinum file I was working with it as-found from the person who wanted it done. I copied the tables, but I didn't catch that problem with the labels.
I want to re-iterate to the Platinum drivers using this ST file. It's a reference, and you should compare the original ST file to my revision to see what was done. Understand the differences and don't just take the changes for granted. The last guy copied literally everything highlighted green, neglecting that ST and Platinum are different models and are going to have different tunes from the factory.
Wow, not sure what is going on, but HP Forums here is having issues with keeping me signed in and acctually posting my responces. I didnt realize this thread was still going, but like that it is! I havent been on in some time due to work and life. But back to play with the tune again and like that I see some testing on it. @jakebrown617 , what year is your ST? I saw the post on my OP file I uploaded being different. I dont knwo what as that was the stock Ford one I pulled. But Only thing II think of is that 20-21 had things like a BOV and other small items where the 22+ they removed the BOV and i'm not sure if they adjusted timing more, or turbo vain controls instead? But anywayrs, just wondeirng what year yours is.
:doh:... As I was playing with the tune, I realized the previous posts referting to OP tune settings was the Optimal Tune settings section! The LS back in the day didnt have this setting, so I am learning new... I thought the OP meant that it was the Original Poster's tune peramiters were off from stock, which is me, and my "tune" I uploaded was the stock factory one with only 600 miles on the OD (Purchased with 8 on the OD... Only miles on her were the factory test miles and the load/unload on the series of trains/trailers until it arrived at my dealer where I recieved a call that the transport will be there in a few min and I jumped in the C7 and raced to the dealer to see her get unloaded) when I ripped that from the truck. So my comments here might not make sense from replying on those tune settings because I was like "my tune i uploaded was factory, why would it be so far off???":confused: suddenly the other day while gathering data and sifting through the tune and testing:drivin:, I went,:bigshock: OHHHHHHHH I see now.... "face palm*:slap:
New to having an explorer st 2021 and looking for help with a tune. I can upload a log if someone can help . It has downpipes and exhaust as of this moment. Thank you in advance
