1 Attachment(s)
OK, I just checked and I don't have your operating system defined otherwise I would change these for you and let you go from there.
You're either going to need to contact Will - minigeist website if you google it or Dave - DStek. You'll need to have the following background tables changed over to the 6.2's TB settings and then you'll need to change the TB setting in the main cal that you have accessible to the same value. Make sure the manifold volume is right for the 6.2's too - I glanced and it might have been. Then you can re-tune everything from there. That will fix your return to idle issues, decel issues and touchy pedal that having these wrong causes. I'm actually tuning one right now with the same setup, so grabbed the pics from it minus it having a different cam.
The tables you'll need to request are the "throttle area" and the "etc max" scaler table. The rate table is the same as the area table in the pic. Ask for them to put them into your cal using the 6.2 truck settings.
Attachment 144041
Thank you The Mechanic for the info. I did the throttlebody clean with HP TUNERS and reset my LTFT and idle is back to normal and idling perfect. Again THANKYOU VERY MUCH
Hey GHuggins . since i did the throttle body clean with HP TUNERS idle is fixed. That other stuff you were talking about. was that what you seen in the log or the tune. I am super new to tuning. i have not wrote any tunes to my truck yep . not that confident yet. I'll have to have some one email.me a tune or a fix . And i would pay for the help not a problem.
What I noticed right off in the tune. These things are torque based and they learn and shift based off of airflow and with one of the main controllers being wrong, it'll start moving one way or the other given enough time. It's real common with just a tb change to do that unless it's forced with model skewing to stay open a certain amount. You can always drive it for a while and see what it does. Take note of idle timing and torque then drive it for a couple thousand miles.
