Originally Posted by
JakeRobb
Have some time to work on it this evening for the first time in a while! I decided to continue giving the cheap TB a shot, just to gain some experience before I sign myself up to drill holes in a $4-500 throttle.
I adjusted my throttle stop back to where it was out of the box, and of course the car stalled immediately due to lack of air. So I opened it back up a bit and let the car idle for a while until it was up to temp. Then I sloooowly adjusted it back again, but the car still stalled (though not as soon). It was stalling when the TPS read 2%, which of course meant IAC wasn't coming into the picture. So I opened it back up again, then did a TPS reset. Started the car and got a 1100rpm idle with 0.4% throttle, IAC around 90. Then I backed off the throttle stop slowly, until the blade was fully closed. The car continued to idle, and IAC showed ~130. Time to drill!
So I popped the TB off the car. I was expecting there to be a small hole from the factory, but there isn't one that I can see. It should be right on the throttle blade, right? Does it matter where I drill? I skimmed YouTube a bit and found only a couple people drilling their factory throttles; somehow I found not a single video of anyone doing this to an aftermarket TB.
Anyway, I don't want to screw something up I can't undo. I'm supposed to drill right into the plate? Horizontally, I think I'll go with centered. Vertically, I feel like I could justify pretty much anywhere so long as it's not in contact with the pivot arm and not right at the edge. Leaning towards the midpoint between the bottom of the blade and the pivot. Is this okay? Is there any reason to do something different?
I'm shocked that I couldn't find an existing answer to this somewhere. I'll keep searching while I await a response. Thanks!
