I went out and worked on the tps/iac. I ended up slotting it as it went down to .37v. I locked it down at .47. I worked on the raf and some blade adjustments. The air flow desired went nuts. This log was on my way home. The truck kept going lean in closed loop. I had to fight it home. That when I noticed on the log the idle desired shot through the roof.
This isnt the first time the truck stalled out or went lean. There are some demons in this truck.
Attachment 162834
