Originally Posted by
Spray-Cam Hell-Ram
I have the exhaust cam min and max set for your set up and based on the fact that you mentioned that half of the full stock vvt range is still available with your limiter so Im guessing you are running the 7 cam degree (14 crank degrees) limiter. If your limiter is not a 7 degree limiter, like the one made by Comp Cams, just let us know what you installed and it can be adjusted. But I have already taken this possibility in consideration in the tune file and only allow the vvt to swing 5 crank degrees at the most in this tune so even if you came back and told me that you installed a 4 degree limiter, like the one sold by BTR Racing, we would still be inside that range and have nothing to worry about. Its safe to test out as is.
