The injector is only in the intake port, not in the combustion chamber, so exhaust valve position is not exactly a factor until the point where that intake valve starts to open. At that [overlap] point, the puddle mass (or gas cloud) on the back side of the valve is allowed to enter the chamber, and possibly make a fast exit right out the [almost closed] exhaust valve, right?
With a larger cam, the intake valve is opening sooner, and the exhaust valve is closing later. The overlap is likely increasing. Firing the injector earlier would keep it firing on a closed intake valve, but when the intake valve does open, some of the fuel gets lost out the exhaust valve. Also, firing too early risks having a different cylinder "steal" fuel from that intake port, which would enrich a different cylinder and enlean this one.
Firing later puzzles me. Unless you wait until after the exhaust valve closes to BEGIN injector spray, don't you still have the same problem with fuel mass getting sucked out by overlap? Or is the puddle mass built up on the back side of the valve so great [stock delay] that a much larger portion gets swept out the exhaust? If we're trying to jump over the overlap phase, we would have to have the new injector BEGIN be later than the old injector END, right?
How many crank degrees are we typically talking about here? And what about bore wash with this additional delay? Do I have my head on straight here?? This is more complicated by considering different sized injectors would have different start times, since it's back calculated from EOI.
I guess if we can't figure it all out, at least we would like to hear how one goes about calibrating the tables.
