Your MAF is way off couple spots high rpm & load. Also off down low. Also, all those timing dips at steady-state throttle and leaving from a stop can be fixed by raising the timing at the rpm and load the dip happens. When holding throttle position at 15%, for example, the timing should be flat with no dips.
