Is your blower ported? If not, stock with just the adapter plate?
Is there that much of a difference if you put in 5500 instead of 5054? What will that extra area effect in the tune? It is not ported just a stock 95mm. with the adapter plate.
my tb scalar is stock with a 103 and whipple setup.
don't waste your time.
has anyone had an issue with the voltage gauge after installing the LT5 throttle body? it goes down to 12 and back up to 14 randomly and will sit at either or, didn’t have this issue going to the L86 from the L83 i have already changed the max area and did a throttle body cleaned cycle any idea?
