Originally Posted by
Joshinator99
You’re welcome! I had to learn most of this the hard way LOL!
So, to be clear, the *LPE HPFP* moves more volume at a lower pressure, BUT NOT the lines and injectors! Thats a big point so please don’t misunderstand me. Less pressure is less flow through the injectors, that’s why it’s important to have the right injectors. That’s why you need to balance the system out! In other words, if you run 2175 and the rail pressure is rock solid but your IPW is 7.0…not good as you know lol. So for that example, I’d try say 2400 PSI rail (LPE is fine there as well as all injectors) and see if that helps, but watch the rail! I tried going from 2175 to 2500 with my setup and it was a disaster, I’m lucky I didn’t smoke anything. The rail pressure will tank like a rock if you ask for too much. If the rail holds fine and your IPW improves, then good and try a little more if need be. Some of my buddies on Camaro6 have run 2900 psi on the LPE HPFP, but they were band aiding too small of an injector.
Oh, and all this assumes you have great low side pressure (I run 80 psi) and no tiny ass OEM check valve that comes in the LT1 hard line. And if you’re smarter than me, you run a +42 or +43 cam lobe (they exist) on the LPE pump, which you cannot run on the LT4 HPFP. That’s another 5% you gain over the LT4.
EDIT: pull up the pump flow chart on any fuel pump. The more pressure you ask for, the less volume it can move. So in that case, if everything else downstream is plenty big, you’ll move more flow through that particular pump at lower pressure. The big question is, is everything else big enough to operate in lower pressure. ;)
