Originally Posted by
7.5in.300BLK
Ok, it's been a long day.
I hooked up the oscilloscope, took the back cover off the ECM x2 connector, and probed pins 17, 18, 19, 20, 37, 38, 39, and 40. Each had a clean injector signal on it. So I went back over and probed 2, 4, 6, and 8, all were getting the signal. I then unplugged all the right bank injectors and got no response from the engine. Then it hit temp and the bank 2 lean went away. I cleaned up the ground behind the power steering pump. I loosened and retorqued the exhaust manifolds. I took the fuel rail off and checked to see if the injectors were clicking. I did a leak down test on the entire engine, none had more than a 12 psi differential from 100 psi. I have solid compression in the whole engine. Bank one runs fine enough to tune, and I could start tuning after it warms up and stops running lean, but it just doesn't make any sense.
