Originally Posted by
eficalibrator
You are groping blindly in the dark. Please stop and find a way to get the ORIGINAL Roush tune in the EEC to start. The Roush file is the best starting point, period. It would include the right fuel injector data and a TON of background changes to ETC, IMRC, and other stuff that you're not going to be able to outsmart them on.
If all you changed was the pulley, exhaust, and MAF, it would have been an extremely easy fix for an experienced calibrator. This car shouldn't have needed custom head gaskets and lower compression if the tune hadn't been monkeyed with improperly. The "original" MAF curve you posted is certainly NOT a Roush curve since it has a noticable bump in the middle. If that was changed (incorrectly), God knows what else is wrong (perhaps someone got greedy with fuel or spark?) with the rest of the tune. Working from this multi-layer clusterfukc is only going to make your life harder.
You need to get the Roush file back into the PCM and work from there. After that, you'll need to solve for the new MAF curve for the Steeda CAI (unless someone is nice enough to hand out the Steeda transfer function), and make the usual changes for an off-road exhaust. After that, you need to ensure that the spark tables include the higher load values that this engine will see and that the actual spark values are appropriate. The change to lower compression probably made lots of areas less efficient than before, so you've now got work to do in both the MBT and Borderline tables. Enjoy.
After you get all that right, then you still have to ensure that the ETC safety checks work right to avoid a possible runaway condition with the higher power engine. DO NOT simply turn off the safety checks or increase the allowable wheel torque error. If it should happen to get in an accident, you would be liable for a LOT of potential damages if these are disabled. Properly calibrating the ETC controls is a several hour explanation and process not to be covered by a simple internet post. (Mr. Fox can confirm this since he just sat through the training a couple weeks ago.)
Unfortunately kids, this has turned into a lesson of how not to do things. Sorry. :shrug:
