Do you have any of this info?
Cam is maga stage 2 blower cam.
231/243 / .561" / 570" 598/608 lift
Map sensor is a 2 bar from jegs.
244-307008
Overbore?
I'll swap out the sensors sides n see if same thing.
I have a extra i believe. If not ill order a new one.
Both those logs you sent are the same. Where I said to load the tune I sent you uploaded the log from the previous. I didn't even check the first until now that's how I noticed. Wouldn't happen to have it would you?
Its a 383 stroker
I loaded it last night. Gimme half hour n ill get back out there and redo it.
Ok. Ill put wideband back in. Want me to start and log it again?
Somebodies doing an awful lot for beer money.
You're a good guy SiriusC1024. Hope he appreciates this level of help.
Yes please. Go ahead and install the wideband. Write-configuration this tune. I've updated a few parameters based on you specific specs. Also, tell me which model wideband you're using so I can track it on the log. It's wired into the A/C pressure transducer, so I'll have to make sure to use the correct conversion formula.
Im 50 years old. I was raised to respect others and my neighbors. To help others in times of need. Yes. I do appreciate it. I just dont post it here. I private message him also. i will do him right!! I know this takes time and is not easy to do. It will be more then beer money though. Im not a dick or selfish and i appreciate all the help, info, i can get from anyone.
If i knew how to do this, i would help people but i dont know how. I would love to learn but i need help learning. I cant just watch videos. I need to ask questions with how my mind is after my accident in 05.
I do help others with what i can do but its not tuning. I weld, i paint, i work on cars, motorcycles, campers, etc. I have always had friends and others stop by to get things done. Ive even gone to them when they cant make it here.
I stop on the side of the road to help others also. Sometime i may need that too. I try and treat others how id like to be treated because you never know when you may need some help.
So yes, i do appreciate this very much.
Got the bung, narrow and widebands installed. Fired it up on your last tune. Runs way better now.
Want me to load the other tune and go for a short drive?
Yeah load the latest tune. Fire it up and let it idle up to temp. Let's see if everything is working correctly.
Yeah. Nim nut here left the pc on top the car and it vibrated off. Broke. New pc now but..... Have new tune in car. In vcm scanner to set the table,it wont show intake man press 2 bar. So i selected the regular one.
Think table is set the same besides that one. Gonna fire it up n log it. I fired it up already ealier. Sounded good
Well you got B1S1 working. B2S1 is still not functioning. It starts popping because B2 is going way rich as STFT increases on that bank. You'll also have to get the 2bar channel working again. Log commanded EQ instead of AFR.
I didn't know both were bad. I'll order another one. Both pretty much brand new. Only start times on em. But yeah, ill get a new one coming.
And change the commanded eq
Thank you
I do have another here. Ill see if it works in the mean time.
heres a new scan. Both are new 02 sensors. Hopefully they are both working. If bank 2 is not, its gotta be the 02 extension harness then.
