2 Attachment(s)
Need help with timing tables
Need some help timing tables. I turned on MAF, DFCO, etc. and also copied over timing tables from a stock 2010 5.3 from a truck (less idle tables that LS Rob adjusted for me). Went for a quick run and once I was felt comfortable engine wasn't lean, did a full WOT pulls. Timing is very low, 5-6 degrees WOT.
I have adjusted the IAT and feel it is accurate. The under hood temps on my car are less than optimal and filter/intake is located behind radiator.
Also, I am running 87 octane. No flex fuel sensor. Suggestions on where to go with timing?
Current Tune - Attachment 146231
Log - Attachment 146232
