Originally Posted by
TriPinTaZ
Do you have a wideband in the car? If not, then you're flying blind. The mods you're tuning for are pretty simple, you might want to consider hiring a remote tuner to get it fixed up for you and then you can have a safe starting point to toy with the tune. For you mods you don't need to set the Alcohol PE any different than the Gasoline PE. You don't need to touch any density multipliers. But you do need to use the correct stoich values, populate the Ethanol Spark stuff, enable the Flex Diag and sensor stuff, and address the Torque Model for Ethanol. Early Gen V ECU's used different Torque Models for E. I'd rather have the car behave the same on 93 pump and on E.
