Open a support ticket, I'll see what we can do.
mustang gt 2017. Can someone tell why we have only this one in OS directory? “Speed limiter patch”. And only switch PATS D/e in system directory
i am having issue with 2013 ford mustang 5.0L swap on 2003 disable pats with hp tuner but no start no spark or injector pulse any help would be appreciated
Mustang gt 2017. we apply the patch (strictly according to the instructions), reset the settings in the scanner, change the PATS switch, everything according to the instructions. but PATS DOES NOT DISCONNECT, pcm does not give a command to the starter. When we unload the file after all these actions (we decided to check), in the OS section the PATS patch is shown as "not applied". what could be wrong?
Wondering if anyone has had a chance to get this set up on the tune file I sent in? 2015 fusion 2.5.
ES7A-12A650-JF
DG9A-12B684-YA
Hi All, Im very very new to HP Tuners, This is my first time using it.
I am trying to do a pats delete on a Gen 2 coyote 6r80.
I was able to apply the OS patch successfully.
What is the exact process to do the Central Config Reset ?
Also while the OS patch was wriring at the bottom of the screen it says to change the pats switch...Is this a different process to resetting the central config ? and if so how do I do that also?
Regards
Kreasen
Hi Mike,
Regards
Kreasen
I could use some help with PATS On 2013 Mustang Gt Coyote swap into 68 F100. My stock tune is attached.
Edit: NM should have read better. Downloaded Beta, applied patch. Worked great. Thanks
Hey guys im also working no trying to remove the PATS on my truck. I disabled the PATS switch under System but still getting a no start issue. Can you help?
Just downloaded the new BETA version but in OS i don't have a patch.
Not working for every OS out there. Email support, ask for this to be added
I emailed my file to support and they quickly responded that its not supported yet but would see what they can do. I'm also talking with another HP Tuner guy seeing if i can get it done through him.
Got my file back and the PATS light flashes but the truck starts. Couldn't be happier
