is it worth it? my car runs out of steam before 7k and only lost .25 off my 60-100 runs when shifting to 4th with my hhr(stock redline bounces 3rd at 100)
id try running a 60-100 in 3rd and nls into 4th like normal, I shifted around 92mph in my hhr when I did shift to 4th and only lost .25 seconds and I have gearing that will go past 100 just over the stock rev limiter, I am going to test more but I think that the 60-100 might be faster in the hhr by shifting to 4th before 90 mph.
I would think so as well, but my car won't allow me to NLS into 4th :(
really? that's odd, does it lock u out? it probally needs to be adjusted.
yes it locks me out, and how do you adjust it?
I personally wouldn't mess with it by myself but there are a ton of tsbs on shift linkages out of adjustment. my friend with a staged cobalt lost 2nd 4th and r, took it in and they worked on the linkage, its broke twice since and now he wants a trans but the dealer he took it to is being a bitch.
on the 08 I test drove when the hhr ss just came out, I couldn't nls to 2nd, but I blew the trans out on my extended test drive lol.
So, byt posted up that i hit 5.3 last night on my 60-100 but I thought it was a fluke, with my car having some extra weight, I hit 5.772 today. BYT FTMFW. Awesome work BYT I sure as hell can't compain. Oh yea mothafuckas mutiple under 6 runs BONE stock with tune, im over 26k and I have not done anything to the car other than put gas in and my oil needs to be changed pretty badly, about 15k on my oil.
Good job :)
oh yeah, it was slightly up hill for the 5.7 but slightly downhill for the 5.3, I really can believe that I picked up so much with just adjustments in the maf tuning. im afraid to change my crusty air filter out.
damn not bad at all, I got my LTFT dial in pretty much but the STFT at still crazy as hell.
But sounds like you really need to change your oil :) just what till you see your filter.. lol
Lol, I'm sure I've seen worse, I used to be an assistant manager at Jiffy Lube, lots of ecotec out there lmao. My LTFTs move around a little bit depending on temp and whatnot, my stfts are almost 0 under WOT. You still running stock airbox/filter? Byt might wanna hook you up with my MAF stuff since I'm still running all stock. I need a catless DP, wonder if my cats gone from me not having COT enabled lol.
5.26 sec 60-100 today. Still some KR WOT at 5k-5500 since I bumped up the timing, up to 16* at 6300 rpm now, no KR. Can't get my 300%+ load back since going with the lightweight flywheel/new clutch. Steepened up the DAL table curve from 70-80%, we'll see tomorrow. More of a light switch now instead of rolling in from 60% up. Miss that 3rd gear wheelspin since it got warmer out. :)
lol good job man, wish I had a clutch lol. I don't think that ill be going very much faster than I am right now until I get some more money lmao. I have the stage sensors and whatnot but I think I need to go catless before I try to get too crazy.
im going to have to go out and try this...do you guys go from 45(or so) then to 100 and just use 60-100, or do you go WOT at 60 and measure from 60-100?
roughly 58ish.
I got a 4.86 sec 60 - 100 from a 58 mph start.... once. 5.2 sec after that. :shrug:
better than what can get :( lol
