Originally Posted by
gmtech16450yz
.82 Lambda? Damn dude you'd be better off if it was .92! Keep that between .88 to .92.
Seeing KR but not getting it actually reducing timing is common on these. It's not normal, believe me. This Bosch ECM is so weird on stuff like this. Look at any other GM ECM and you can clearly see KR numbers exactly taken away from desired timing. For example, if you're showing 5* KR, and you're commanding 20* in your tune, you'll see 15* in the log. The other thing about tuning most any other motor is if you get 2* KR, you reduce that cell in the editor 2* and you'll never see that 2* KR in that area again. It's not that precise obviously, but pretty darn close. On this LNF, you can see 2* KR and reduce timing till you're blue in the face and the car barely runs, and you'll still get that damn 2*! Or maybe it will just go away on it's own without doing anything, only to come back in another spot at 5*!
Sucks seeing these low timing numbers, these motors REALLY need better fuel to run good. Hopefully with the gas prices back up we'll see more E85 stations popping up.
