Bluecat, please shoot me an email [email protected] when you have a moment, I sent an email to the one I have on file but not sure if you got it or not.
Thanks,
Bill
Thanks,
Bill
awesome, thanks. one more question though, and i'm sure this is a simple one too, regarding the samples. when i try to open one of them i get the error message in the attached pic. do i just need to update my .net framework somehow or is there something else i'm doing wrong?
Thanks again :cheers:
Adding axis labels to the 3D Graph would take a little work. That's why they aren't already there, lol. Also I actually went to add a marker in the table to show the location of the graphs pointer, but the way its setup currently it creates a redraw issue. It not a big deal, but I wasn't ready to spend the time with it that day.
I love .net. That file hasn't had that extension at all the entire time the new version has been developed. I have no idea where that came from. There isn't a single reference to "table_dim.txt" in the entire project. I just checked lol. And the old version wasn't even remotely upgrade-able by the vb6 project upgrade wizard. So I had to copy and convert every line of code by hand. And I'm pretty sure I changed the extension as soon as it was copied into the new project. I don't even think it was compiled or ran a single time as ".txt"
No idea what to tell you on that one. It just when opening one example ve?
vb.net?? AHHHH!!!!
Looks good though. :)
EDIT: figured it out i think. if i open EQ VE and then file>open>sample file, it works fine....i just can't open the sample folder and then pick a file to open. no issues now!
i can't seem to open the .BVE sample files though, only .BEQ's.
if i open a ls2 example file in the ve table and try to copy and paste my e40 ls2 ve table it doesn't work as the map hystogram reference are different 15,20.625,26.25,31.875,37.5,43.125,48.75,54.375,60 ,65.625,71.25,76.875,82.5,88.125,93.75,99.375,105 so it will paste only the column without decimal (15,60,etc..). The second one for example is 21 on hptuners so it will not be pasted.
Is there any way to let it work at the first or do i need to change manually the hystogram settings and then paste it?
Got it, thanks guys.
Cheers!
Don't poke to much about VB, lol. :D
I've been writing in Basic since I was in the 3rd grade when it was gwbasic.com and basica.com. Even a few years later when I needed a more powerful platform I wrote in assembly with MASM and linking the obj files back to calls from basic. It wasn't until I was teenager that I started using C. I still use C quite often, especially when doing microcontroller stuff. I know several languages, but Basic is and will always be my "native tongue" so to speak. :cheers:
Yeah that's my fault. The KPA values in the ls2 format are not even. They are 5 5/8 (5.625) kpa per cell derived from 90kpa / 16. Because my program on the equation side does table lookups, i didn't want the raw data to be rounded. I display them rounded in my views just like HPT, but HPT actually has the axis data rounded off. And when doing table pastes with labels, they have to match perfect to what they have or they don't go.
Can you just paste the selection with out the label data? It should go then as axis formatting is irrelevant.
EQ 3.5 was still installed on my laptop when i tried opening the bve sample files, it was the default program for those file extensions. i've uninstalled it since then and now know to open the sample files from the eq ve program, and not just click on the file itself.
There isn't the paste only function with right click on your program so it doesn't matter wheter in HPTuner i do copy or copy with labels....i can select paste with labels only....i tried also paste average,etc but still not working...
If you include paste only function it should be solved.
I know this program is not intended to use for E40 but i was playing on it to see other GMVe tables and i think it might be useful in some circustance to do paste only even for other cars ECU...
You don't have to pick from the advanced selections on the sub menus for copy or paste. Clicking the copy or paste from the main context menu that the sub context menus branch off of is just the normal old copy and paste.
