I had changed General >> Displacement to zero (see image). It initially looked like this works as the ABS, Tractioncontrol, CEL, Brake etc... lit up the cluster.
This was on a 2WD dyno.
The issue was not the ESP but rather the autostick manually would not respond. We were stuck rolling in first. It would not move to 2nd, let alone 4 for us to make a pull.
Good to know this can be quickly done in the scanner.. but i suspect Id run into the same issue with the autostick.
Attachment 74290
Are we confident that changing this to Zero is enough? What else is missing so that we can manually go from 1st to 4th to do a WOT pull?
