This helps save some time... can we get a functioning undo button?
Ahh yes.. undo as well is on the todo list..
Higgs,
Wat u need to do really is log the % error between ur maf and log also ecu desired maf also the same thing for measured map vs ecu desired map and apply the changes i will be sending hptuners support the tables to be added to allow the ecu to use measured map and measured maf instead of back calculating and chasing it self
It's throttle desired airflow vs maf airflow (I log both in g/sec)
And
Throttle Desired map vs actual map
I log desired airmass and compare it to actual as well...
Jarrah thinks for getting that added
thanks guys, very cool on all accounts
Very very cool guys. Thanks!
Seems like we might be making leaps and bounds now - thanks Jarrah - big plus to you on all of this! Not to mention HPT and everyone else...
Do you also log these errors to dial in the driver demand tables or do you just dial them in more for pedal feel?
hey keith, check your pm's!
Area47, it's best to post tuning related questions on the forum.
Also, I don't have all the answers.
I am getting an error when attempting to Extrapolate Coefficients.....
Please remember that this feature is in active development. Bugs are fixed and features are added to it every day.
Keith, can you make it to where it modifies the b,c and d tables too since it always seems that these tables are the same... All it modifies right now are the "A" tables...
You could arbitrarily build an equation to calculate TQ based on airflow and rpm to give you somewhat of a linear basis to start from. Until we can get plugs to input the data from the dyno it's going to be difficult to calculate it.
Me personally I plan on manually inputting TQ values from various points using steady state on the dyno and interpolating the rest from there.
Beta version 3.5.72 is crashing every time a file is edited and attempted a save on a file I was working on. It destroys the file as well. Sucks, had to redo that file completely.
Emailed support twice and haven't gotten an update. I have a modded Z06 A8 on the dyno right now and would love to play with this.
Just killed my file with 3.5.73
Going to About it says Version 1.8.1....
Dang good thing I'm not modding files tonight
