Cool, ill take a look and see if i can do it
what interface are you using and in what mode...USB, wifi, Bluetooth? Also what does your advanced settings look like? Remember, alpha does not work with the HP tuner interface.
Attachment 125862
what are you trying to do?
you know its not a real brake... it uses the abs
can add it to a non 1320 or HC with a tazer
as far as holding rpm that is a different box (2 step)
Reviving to see if anyone's made any progress on adding trans brakes to non 1320 or demon vehicles
i would talk to these guys:
Who is that? I don't see a company
The demon trans brake is a "real" trans brake. It locks the trans in 1st and 2nd at the same time. Old ones would do 1st and reverse they did it this way on the Demon incase 1 gear fails the car won't go flying in reverse.
I know, I was wondering if anyone has been able to implement the trans brake to non 1320 or demon vehicles, sense they use the same trans(hp70&hp90)
