1 Attachment(s)
A must read if fighting idle
So finally got back out to the car and after all that work on the vt tables it still had a slight surge in park and got worse in drive but it got stable more often then trying to stall or go over 1200. I let it run for a few min to get temps up and saw stft was -12 so I trimmed both the maf and vve a touch at idle and that nailed it. I could see on the log it looked to be dipping lower then my commanded in the virtual torque tables and noticed that it was going really lean on the wideband like over correcting for it being rich. So by pulling out 5 percent on the maf and on the vve the timing came up and throttle closed down and idle is right around my commanded 675 in park and 700 in gear. I couldnt ever get it to idle with this much timing in the past until I made the airmass and virtual torque more in sync. Once I looked at my log and saw .30 cylinder airmass and 75 kpa I went in to the vt and made sure that in the idle it was very close to each other doing that getting the fueling correct brought the idle timing up and closed the throttle. It seems when they are not close and more on stock settings that it wants to use one or the other to try to achieve commanded torque in that area it idles. Every single time before I was getting the throttle to close down but was also pulling timing out to get to the torque values. the odd thing is it is idleing with near zero zero pedal torque so I might be able to come up on it a little Im going to play with it some and try to learn more. I am not near the values in the external load table I could put 20 in that and it would be fine how it is idling now. I also had a slight swing when went into gear so lowered my speed control reserve down some and that made the idle more steady in gear. Throttle response is incredible too with the tables set up this way. Not the lazy gen v throttle response at all. I even see a little boost now when I nail in park. SO It is commanding more throttle for the first time when not in gear. this all just show how important the torque coeff tables really are on this platform. I feel with enough work on it I can get it to command a true 100 percent when not in gear but I am worried it might mess with how it drives so it sounds and feels good now so if drives as good like it had on my older vt tables Ill leave it and be happy with how it is now. Seeing my methanol trigger in park when I floor it means its making at least 4 psi on a quick stab and that is night and day to how its been in the past and didnt have to rape the driver demand table to do it. Everything revolves around this model being as close as possible. I feel now the virtual torque is more important then the vve being correct but they do work together and will probably have to re address my vve again just to double check it.
The one thing that bothers me is that I can still force it with a little throttle input to idle with lower kpa and timing. the more timing its adding the lower my kpa is due to making more torque. I can actually make it idle with .24 cyl/air and 60 kpa if the timing is at least 20 and throttle is down around 9 percent. So it can get even better then I have it now. But what that will do it off set the vt tables yet again as I have them currently at .30-.40 and 70/80 kpa the torque values are lined up more to that. So in testing I may try to off set it to what I see if I give it 12 percent of pedal input on the throttle just to see if it will then try to get the same results while it is at a true idle with out me leaning on the pedal a touch.
But I promise you this is key set up your torque tables to what you see on your log make sure its not too rich and over correcting and it will idle so much better. I am attaching a log to show where it is now and you can go back and see on an older post how it was in the past.
I hurt inside reading this entire thread!
Quote:
Originally Posted by
sevinn
Drop it in open loop and throw some fuel at it and see what happens. Might just be lean. I had this issue when my wideband and my narrows weren't agreeing.
