its stock
its stock
I'm having the same problem with my 2020 Pro Xp4. It keeps saying failed.
I had another 2020 XP4 that won't connect and a 2021 Pro XP4 that doesn't connect.
Does anyone have a stock file for a 2013ish RZR 800? I just got my cable and I'm trying to determine the difference between the Ranger and RZR tunes.
Also for some reason I have to be plugged into my adapter to open the Ranger tune that i saved on my laptop. Is the file somehow corrupted or is this a known issue?
Great work. I am hooked too.
Can anyone share a pinout of the adapter cable?
SOME 20-22 Pro XP cannot be read via OBD. If you have the Blue 02 sensor cover. Cali edition. it will not work TPROT is active.
Bench read only for full file and EEPROM.
There are 43 Variations of the pro XP OEM calibration I have identified so far.
tune alone I've had these to 194 rwhp with zero other mods 106 mph 20.5 psi. 167 rwhp stock 87 mph
Few more load limiters to address. throttle cuts back to 60% at 200% load once we are past 102 mph
anyone locates that hex address. lemme know. I mod the Hex dump. Here's a stock brand new 2021 OEM pro XP bin file if your curious about what's in the actual unlocked code.
Attachment 118456
any news on how we are gonna tune this pro XP cars i have one too??
I just got the Polaris adapter.
Trying to DL the stock tune on my 2021 Turbo S with Beta 4.11.983 and I am getting a "Detect Protocol Failed"
I tried "Gather Info" as well with the same results.
What am I missing or what is my next step?
It is Stock. any reason why the beta wont open up anymore.
Is there any way to look at a stock tune I've saved from this thread if I don't have a MPVI? I downloaded the beta vcm and a tune from this thread but cannot open it. I'd just like to look around before purchasing.
Hey Derek or VFORCEJOHN am I correct that we can't even use the scanner on a DJ tune or am I having another issue?
I've been having the same problem trying to read a 2016 XP 1000 turbo, click on read vehicle and nothing happens! can't exit out,froze up have to manually shut down lap top. I guess i will download the Beta and try it
So.....downloaded Beta,was able to read vehicle but once i saved file and tried to open it i got validate checksum failed,unable to save file controller M17.8.7
Now what?
