1. You see not modified values on the screenshot.
2. I just switched both debug flags on.
What do the debug flags do exactly?
hello all
Does anyone have success with burbles on 1.5 4 cyl ecoboost?
stock attached
Try this
Thank you. I apologize for the delay.
Unfortunately, it doesn’t work: no matter how hard you accelerate, there’s silence.
And there is an unpleasant moment while driving when you release the pedal to brake the engine at rpms above 2500 - the car begins to twitch and you can hear popping sounds.
Here is the work I have done with DFCO and MBT Map Points. We still cannot get burbles. There is no Burble section for this year and model but here is the tune I have done. Any advice or adjustments would be greatly appreciated. (Car still has a cat)
Attachment 156854
01/25/2025
Disable DFCO
Enable RPM-7000/Disable RPM-3000/Enable VSS-250mph/Disable VSS-0.00mph
Disable Load 0
-(Engine)/Spark/Advance/CorrrectedAdvancedTiming/MBT Map Points 0thru3 set to 30 for 3000 rpm and up for the first 3 rows
-(DFCO) Enabe RPM-7,000/Disable Load-0
