Originally Posted by
SiriusC1024
Right, but this is a different setup than LS. It's a BBC. No rocker bolts to lock down. No trunnions. Preload is set with the rocker nuts, not by changing pushrod length.
Take a look at the parts list on Post #60.
There is an instance here where changing to different length pushrods would be warranted. Once preloaded wear pattern on the valve tip must be checked. If it's too far off center then a different length will need to be selected. It can be hard to judge the contact pattern with roller tips. Put permanent marker on the valve tip and see where it wipes away. Due to the rollers, might have to wiggle the rocker side to side while rotating the engine over a few times to get it to wipe away.
It's tedious stuff. Don't be in a hurry. Pick a good few hours where you really don't need to be doing anything else. Otherwise you'll get pretty pissed off lol.
