I having trouble locating this injector date for the gen 3 and see you have them any help would be greatly appreciated
12594512 - 36lb LMG, LC9
@blindsquirrel
Think you could help me out?
2007 E38 4.8 Truck, need to put injector data for a 52# LSA into it, but a bunch of non-editable scaling is different.
Attachment 146158
@blindsquirrel all of the fuel tables are correct including the transient tab or just the fuel general tab. Just want to make sure as I dont want to hurt my new 416 set up just want to get it running good enough to drive to tuner to be put on Dyno and tuned.
Transient stuff is tuning stuff IMO, others disagree. But I've never seen an injector datasheet that includes anything about transients same as I've never seen one that includes a VE table. Just because a thing needs changes or adjustments based on collected data with different injectors doesn't mean those things are part of the injector's characteristics.
Thanks for clarifying, I knew spark, idle, airflow, iac, and ve for sure needed to be tweaked which I have adjusted for I was just unsure about the transient. Some people zero out some of those tables. Just need the starting base so it runs not stumbling on its face first start up. Thanks for clarifying and submitting the data:) Stay humble!
I have seen a data sheet with a transient fueling table. I did copy it over, the difference was so small it would not have made a difference. Im guessing different injectors may have a different spray pattern, possibly changing the way the fuel collects on the port walls or the difference in droplet size?
Yes but whatever data was provided you could just as easily got to by making adjustments based on how it behaved. i.e., it's just tuning, it's not hard specs that shouldn't be fiddled with like the other injector tables.
Hi I've got a cammed ve ss manual I've been having problems with tuning at several shops but I've just realised someone has put ls3 injectors in it are ls3 injector data why different to l98 injectors?
Sorry no I was just asked would the data for ls3 injectors be different to l98 injectors
This is the information I had found way back when for the Deka 80 injectors.. it may not be of any help, but I figured I would share it.
Specifications:
Static Flow Rate: 80lb/hr = 875
cc/[email protected] PSI
Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms
Period
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Connector: USCAR or EV6
Series: DEKA 4 (DEKA IV)
O-Ring Type: Viton
Cross References:
Siemens FIl14991 or 109-991 (
109991)
Hello everyone
I'm working on (what I was told) a 2002 6.0 with 25317628 injectors. it has a painless ECU and harness. Do any of you have the data for these injectors?
Stock low perf 28lb injector for any
CHEVROLET SILVERADO 1500 00-07 V8-4.8L
CHEVROLET SILVERADO 1500 00-07 V8-5.3L
CHEVROLET SILVERADO 1500 03-07 V8-6.0L
CHEVROLET SILVERADO 1500 HD 05-07 All
CHEVROLET SILVERADO 2500 01-01 All
CHEVROLET SILVERADO 2500 2000 V8-5.3L
CHEVROLET SILVERADO 2500 99-00 V8-6.0L
CHEVROLET SILVERADO 2500 HD 01-07 V8-6.0L
CHEVROLET SILVERADO 3500 01-07 V8-6.0
Use any stock tune file for a transfer of data.
Any stock 2003 Silverado LM7/LQ4 file if referenced/return style, or any stock 2005 Silverado LM7/LQ4 file if non-referenced/returnless. That's an old number but it crosses to 25320287/17113698/FJ10062/FJ315, the default generic injector used in all over in the non-flex trucks from 2001 thru 2007 (not every single one, but lots and lots). They are only 24lbs, make sure they are big enough for your plans before potentially wasting time on them..
I have to say this is a great discussion thread. Thank you for all the help. Getting ready to fire up the old 4.8 with a nnbs intake with 38lb injectors and gold blade tb.
Attn: Blind Squirrel
Do you have any data formulated for running LS1 injectors 12561462 in a 2009 Trailblazer E67 12630465? I can do it properly, manually but it's a time suck. I have a lot to do before leaving on vacation and just can't really afford the time. Happy to pay. [email protected] if you need to send anything over.
There isn't enough data in the Gen 3 files to fully populate the whole tables in the Gen 4 files, the tables cover a much much wider range of pressures. Gen 3 only goes from 0 (normal atmo) to 80 (20 kPa MAP, or max vacuum) kPa; the Flow Rate table isn't that difficult as flow rate is near enough to linear and can be extrapolated, but the great big Offset table in the Gen 4 would be left mostly blank either side of the 408-488 kPa Delta window. If you're exclusively naturally aspirated, and running 58psi rail, and no FPCM so the rail pressure is always 58 no matter what, that's the only range that your combo can ever utilize, but it's still not the whole dataset.
If you're running a referenced regulator it can also work without having the full range, as all the columns are the same all the way across and only need one column from the source data.
In short, maybe, but only depending on how you are using them.
Yes it's NA and I know about the tiny part of the IFR that will be used and the tiny square of the offset table that's used as well. I just began removing the .5 volt rows and thought "I bet someone has already done this and could get me rolling quickly".
quick question
25326903 interchanges with 12580426 Correct?
psiconversion.com thinks so
https://www.psiconversion.com/tech/l..._injector.html
Need to see if anyone has injector data to convert this to a returnless fuel supply
Injector: 17113553, 25317628 22lb stock injector MULTEC CONNECTOR
58psi Corvette returnless filter mod'd.
Fuel Injector
Part# 17113553
Per Veh: 8
Years: 2000-2000
Additional Fitments
VIN: T, Auto Trans, Eng Code: LM7, 4L60-E, 4 Speed Trans, Transmission
Going to be using a manual OS for this but need the data from the bone stock motor.
Attachment 149013
No, not from any stock file anyway. They were '99-'00 truck only and didn't carry over into the returnless era.
You could pretty safely fudge the flow rate since that's close enough to linear to not make a difference, but the Offset table isn't anything you can recreate like that.
(sample returnless data, truncated to show only 0 - 0.5ms range)
Attachment 149030
It is bone stock and going to stay that way. In fact it will be a little detuned. Going in a DeLorean and don't want to break the transaxle even though it has the billet input shaft.
Yeahbut making it idle right and predictably come down to idle and all the rest of the fiddly stuff has nothing to do with how much power it makes or whether it needs billet unobtanium whatzits. The 'important' injector data is only in play at very small PWs.
Why not put in a set of 25lb injectors from a 01-06? Its not like they arent in every junk yard.
GM_50lb_12613412_Flex_Fuel_Injector_to_Gen_3_Injec tor_Format
Data for both return and RETURNLESS/DEADHEAD data.
Attachment 149039
Already been done. https://forum.hptuners.com/attachmen...3&d=1707139116
If my data/conversions are wrong and that goofy sheet up above is correct, then GM's data is wrong too since that's what my conversions are based on. I just don't know if that sheet came from an actual characterization bench, or was done with the LS3-to-LS1 conversion tool, which by the way, does not work on anything other than the 128-640 axis early E38/E67 source files. One glaring clue that it's a bunch of horseshit is right at the top of the page:
12613412 was never used in any 6.2L RPO. 12609749 was, but that's a different injector with different characteristics, despite being a similar flow rate, and for the longest time lots of people conflated 12613412 (L96) & 12609749 (L92/L94) and used the same data for either.Quote:
GM 50lb 12613412 2009-2013 6.0/6.2
Attachment 149071Attachment 149072
This should be close enough. Use at your own risk.
