Re: Zeitronix WB Settings in v1.5
The following is the last formula that I got from Zeitronix which should be the "be all, end all" formula for their wideband.
Quote:
The table has the most accurate values. If you need to know AFR/V points between the ones in the table the best way is to interpolate.
Here is a polynomial you can use between 10 and 14.7 AFR.
LAMBDA = -0.0013V^6 + 0.0116V^5 - 0.0163V^4 - 0.0779V^3 + 0.29V^2 - 0.1994V + 0.7307
AFR= LAMBDA * 14.7
Hope this helps.
Thanks,
Zbigniew
Play with that. :)
Boy, you're going to need a supercomputer to process that fn live. lol ;)
lol, I think that other one Firehawk mentioned is the condensed version.
AFR =1.3127*V^2 - 1.2163*V + 10.428
Keith,
Put an update on the server , if would like me to test this formula out.
I think this is the one we need for Zeitronix.
Let me know.
Dave
New updates with new Zeitronix support for:
Magic Chicken
Dirk Diggler
2000Firehawk
Zeitronix 1 is the same formula
Zeitronix 2: (1.3127*(V^2)) - (1.2163*V) + 10.428
Zeitrnoix 3: (0.627*(V ^2)) + (0.457*V) + 10
Now, you guys all seem to have different results. Some are off by .2, some are off by 1.... this is a real nightmare...
What I need from you guys is this... If you could map raw voltage to the AFR, or build your own user defined list and see what works for YOU... It is hard for me to define 1 formula when you all seem to have various results..
If you think you have a "magic" formula, let me know and I'll add it as Z4.. or Z5.. or Zn... cause this is ridiculous..
Create large log files and try to vary AFR from 13-15 if possible... and send me your .hpl files, this helps me big time.
Thanks Keith, you rock. I'll get some data as soon as I can.
Quote:
Magic Chicken
Dirk Diggler
2000Firehawk
Dirk Diggler doesn't have a Zeitronix, I do. He was heping me. I could help you if you wanted to give me the update Keith.
This is the formula I have in my efilive and it seems to produce vaild numbers. for me.
(0.627*(V ^2)) + (0.457*V) + 9.3508
Dunno??
Cool...
Got it.. :cheers:
Dave
Black02SS, new update for you on webserver.
Zeitronix 4: (0.627*(V ^2)) + (0.457*V) + 9.3508
Dave, check your email. I sent you back your logs.
It appears from your logs that the +10 formula works "best" for your situtation. I haven't had a chance to check mine out and see what it is. It still isn't a constant. Here is a exapmple from his logs if anyone wants to know. All of these are averages.
Zeitronix +10 +9.7758 +9.3508
13.6976 13.71231 13.4881 13.06311
14.6214 14.57669 14.35249 13.92749
I just checked this formula as well.
Zeitornix 1.3127*V^2 - 1.2163*V + 10.428
13.6976 13.65333834
14.6214 14.88513863
This should address your problems.
EDIT: Here is the link to the file for HP Tuners
http://www.usionline.net/zeitronix.txt
Hey Keith! This works how about a discount on my copy of HP Tuners. I will send you my LS1 Edit cable... :D Call it a free lance developers fee. A tax write off for you anyway... :cheers:
http://www.usionline.net/zeitronix.jpg
By the way.. I don't see how you are getting any good results with these other formulas:
http://www.usionline.net/compare.jpg
I inputed your formula into 2000firehawk's file and it seems to be off.
Unless he came up with those charts from actual logged data, they will be off. Zeitronix has such wide swings in V/AFR it's hard to get one formula right for many different units. It almost seems as if each unit is unique.
Your formula calls for ...+9.41
When I used that with his data it was off. I altered the last value to ...+9.76671 and it plotted it just fine. I think the output from the black box might vary from car to car. It appears that your formula will work fine, just need to alter the last factor to each persons car. PITA
Yes I agree you may have to adjust the Y intercept, I adjusted it slightly to fit as it is.
I did not use any data... just the information from the green sheet from Zeitronix.
Used this to come up with the formula.
Plugged in the values.
I don't have the software, but am confident this will be accurate enough.
The new formula is:
y = -0.2662x^6 + 2.5665x^5 - 9.0496x^4 + 14.54x^3 - 10.127x^2 + 3.7873x + 9.4089
I tried it against the values Dave had in his logs, and I'm off by maximum of 0.1 AFR, while the other formulas would go off as much as 1.12 AFR.
I have all my work in an excel spreadsheet, I could post it if anyone's interested, or just wanna double check my work. Lemme know, and enjoy your new formula.
Marcin
BLOWNZ06
I thought we all agreed way early in this thread , that the "Green Sheet" data was bogus for the Analog output ??
Does anyone now think that the 'green-sheet' data is correct ?
