I just got an email from Bill on version 2.22, is this the new version with the new parameters?
Yes. Please! On my 2008, a single run from 0-60 will cause COT to kick in on the very next run. FWIW, I get more boost (17-18 PSI) after COT kicks in than I do before (14-15 PSI). Need some way to control boost to make it consistent with/without COT. So when you guys get to the turbo/boost tables, make sure we can control how COT affects boost.Quote:
Originally Posted by shabby
Mike
Where is this table, I can't find itQuote:
Originally Posted by Chris@HPTuners
I just found itQuote:
Originally Posted by DEJON-Dave
Has anyone tried adding something like 10% to the higher load values (like increasing the numbers in all columns from 70% to 100% up by about 10%) to see if that results in increased boost? If this table does what the name implies, the ECM should "learn" the boost UP if you do this, similar to how it learns boost DOWN when you do the wastegate mod.Quote:
Mike
Yes it does,you can build your own boost map,kinda cool....Just be careful.
OMG! Just tried this! After about 20 minutes of fiddling, I had my boost exactly where I wanted it in just one shot, just by doing some simple calculations and adding a percentage to the desired air load and max air load torque tables. I wanted to leave the wastegate mod in place (to get quick spoolups) but increase the boost. Even with the wastegate mod, I was only getting 15-16 PSI of boost sustained. Now, I still get the quick spoolup and my boost pressure is a constant 20-21 PSI, exactly where I wanted it! I did lots of testing and no limp mode or any signs of trouble. And... this thing SCREAMS! Full throttle starts are no longer an option with traction control off. The tires completely go up in smoke until you let off the gas, and that's with an automatic.Quote:
Originally Posted by SEGA
I had the BSR tune for a while, but my car is a 2008 and for some unknown reason, I could never get it to work: limp mode galore. This preliminary tune I just did feels as strong as the BSR tune without the limp mode issues! I only have two nit picks that I may work on:
(1) When I first slam the gas down, I get a momentary (maybe 1 second) reading of 25 PSI on the boost gauge. After that, the boost goes down to 20-21 PSI and stays there. My car has always had an initial "spike" like that: even before the tune, with the wastegate mod, I got a spike of 20-21 PSI and then a steady 15-16 PSI, so maybe the spike is normal? Doesn't seem to hurt anything and I feel no associated "surge".
(2) Boost comes on a little quicker with varied pedal pressure. It's kinda hard to modulate. For example, if you very slowly press down on the gas more and more, you'll see boost start to rise with pedal position, 2 PSI, 3 PSI, 5 PSI, and then all of a sudden it jumps to 15+ PSI and stays there. I believe that's because I only changed the 70%, 80%, 90% and 100% columns in the table and the air load called for in those columns requires (more) boost. I don't think it's a problem, because the BSR tune was the same way: boost came on all of a sudden instead of smoothly. I may fool with the tables a little and see if I can smooth it out a bit.
For now, I'm happier than a pig in poo! :D What are the rules on uploading tunes from this beta? I think my tune could be helpful to others, but I don't want to break the rules if it's a no-no to post beta tunes.
And, I also agree it is wise to be careful and go slowly with increases here! Perhaps even a warning message is called for in the final release so that if you start fooling with those tables, a warning pops up about turbo boost getting out of control and possible damage so much care is needed when fiddling with those tables.
Mike
As long as its YOUR work & not the work of a professional tuner that may or may not want his/her work public its fine, also its a public version of software not beta so thats a non issue as well.Quote:
This is where the whole "self tuner" thing comes into play & everything you said is true, play it safe & make only small changes. This goes for every calibration, not just a factory turbo charged one. Any change to the pcm can ultimately cause a hard part failure, it just happens that FI or nitrous exaspirate things.Quote:
I will say we are very pleased that most are seeing great results!
I am working on my tables and have found great gains from increased boost but I will verify how everything else looks while on the dyno. have done some pulls/logs on the street with no signs of problems but I have already added more fuel and some timing for a safer a/f. I am running at about 11.1 now where as the stock tune. was high 13's wot. thanks HPT!!! still waiting on the wb pid.
Bill had some good advice ... but if you did mods to a table then there should be no issues with a screen shot of the table changes that you made. You could show that in comparison to the same table in the stock tune. I would only do this if the table in question is all your work and not that of someone else.Quote:
Originally Posted by mikeysolstice
Is there a definition of what air load actually is? Is it a certain amount of airflow?
What kind of % increase did you do?Quote:
15% in the 100 column, 10% in the 90 column, and 5% in the 80 column, only from 1500 RPM up. Then I did some vertical smoothing. I also went up 15% on the air load torque table in all cells. I'd also like to know what those numbers represent. I know air load is usually considered the "charge" or "pressure" inside the intake manifold. So can we assume maximum air load is the maximum amount of boost the ECM will allow before going into limp mode? That's the way I read it... although I have no idea what the units are here.Quote:
Mike
Can you post a picture of the modified tables? or the tune? Great work!Quote:
Wow, I just opened up the HHRSS auto and all trans functions are in there. Is that new as well?
Not that I'm aware of, might just be using a common TCM with something we already support.Quote:
Originally Posted by Baldturbofreak.com
The only two HHR SS/TC files I have look to be manuals.
Quote:
Originally Posted by 405HP_Z06
one page back, look at this cal.
Yeah, looks like they use a tcm we already supported. Looks similar to some of the 08' truck calibrations I've seen lately.Quote:
It's not there for the GXp's yet, but good news for the FWD crew!
Man I tell ya. 10.5" tire, 3200 stall +GT30R would run bottom 10's on a 1.2 60 ft...
What seems to be the upper end of boost people are running? With my ~15% increase in the two tables, I've gone from about 16 PSI up to a sustained 20-21 PSI so... while I'm happy with that for now, I know I can go further. Question is, how far should I go? Common sense tells me I could do 23 PSI since that seems to be a popular number for some of the other tunes. Is that the accepted "upper end"?
Mike
any ideas on the wide band PID...just wondering.
