Vortec
16258745
Dodge
05030232AE
I4 512k os 16250871 receives VATS Fuel Cut B switch
P12 pcm’s receive
To and from cobalt ss/sc unable to connect error fix
E77/E69 pcm's receive
Several overboost/underboost condition diagnositic test tables and constants
Map sensor tables
Wastegate & BOV tables
Fuel pressure tables
Injector tables
Fan tables
Spark tables
512kb & 1024kb LS1 platforms received
Options matrix
Platform type switch
Fan recirc switch
TPS High & Low fail constants
About a dozen new rolling idle tables and constants
IAT Scalar table
512kb LS1 pcm’s received
Cranking spark table
9375577 received TPS High & Low fail constants
os id 12212156 received
Upshift D2 2nd
Downshift D2 2nd
Upshift D2 3rd
Downshift D2 3rd
Following os id’s received Impact factor gain vs airflow, fuel on wall exp decay mult vs airflow, transient fuel min rpm, transient fuel max tps, min fuel milligrams & fuel from wall stabilization
12579405
12216125
Following os id’s received fan desired% v sect & dfco tps minimum
12579405
E38 & E67 pcm’s received
Roughly 50 new tables described here http://www.hptuners.com/forum/showthread.php?t=28498
The following E38 os id’s received 1-2.5 bar vcm enhancement:
12612381 12639270 12633056 12635863 12605732 12614676 12612281
12617631 12628990 12624402 12633016
E38 Starter check patch applied to:
12614676 12614088 12630501 12605732
12615493
E37 Starter check patch applied to:
12618032 12618044 12610011
E38 P2101 Throttle parameters added for
12617631
All E38 operating systems receive the following speed limiter constants
Speed Limiter 4WD Low
Speed Limiter Comms Fail
Speed Limiter Steering Fail
Speed Limiter Minimum
Speed Limiter ETC Fail
E67 OS id 19211212 received 1-2.5 bar vcm enhancement addition
E67 pcm's can now perform write calibration only without error
All E40 os’s receive cranking spark table
E40 os’s 12596734 & 12596660 received
P2101 Throttle tolerance params
T43 TCM's received a major 150+ table update including TM & TCC lockup tables requested
E37 support released
GMPP E67 pcm support released
GMPP EROD pcm support released
2009+ Allison TCM support released
2010-12 Camaro V8 ECM/TCM support released
2009-12 Corvette ECM/TCM support released
2009-10 Mustang V8 ECM support released
2009-10 Savana/Express V8 gas support released
2009 G8 V8 support released
2002-2011 Ford BA, BF & FG support released
2009-2012 Escalade ECM/TCM support released
2009-2012 Silverado/Sierra V8 ECM/TCM support released
2009-2012 Tahoe ECM/TCM Support released
97-04 V6 pcm’s
Received several open loop and injector tables added to all 700+ operating systems
Ford credit licenses lowered to 2 credits for single vcm licenses
Ford Scanner rate updates for faster scanning
Fixed airflow table address in Aust. Ford operating systems HAEDG/HADCK
Raised upper limits on pulse width min constant
Ashame no E55 controller gear....
So when will 2.24 be finished..oh sorry:burnout:
ive read this whole thread and joined this forum just to let you know that there are a lot of v6 owners out there that want a tune and there are a lot of tuners that want to be able to tune our v6's with your product... I understand how you might feel that the demand isnt as high as the v8's but i dont think that is on point. We v6 owners are waiting (the ones who havent gone to "trifecta") for your tune to be released... Im not knocking you guys at all and i am def waiting for your tune, but you gotta stop givin some of the posters a hard time for asking and asking about dates and what not... the people that are trying to develop cam shafts for us are gettin the same questions as well.. i desperatley want/need the tune.. ive recently added a nitrous system along with some other performance upgrades but really neeed the tune to set it off... PLEASE PLEASE understand that we just want your tune and not get mad when we show our interest....thanks :)
I'm gonna close this thread guys as it has run its course, the answer is clear it will be looked at after 2.24 is released. There is no question on demand, we have already decided yes.
Chris...
