The switchover delay just fixed this problem I'd never previously been able to figure out http://www.hptuners.com/forum/showth...light=throttle
Thank you for posting it.
Honestly...I just hadn't paid much attention to tuning the car for quite a while until I did the heads/cam setup over the winter...and now I've been attacking the PCM from every angle I can.
For what it's worth, I'm actually using an E40 on my other car...it's a Gen 3 engine, (callies crank/rods and JE pistons in an LQ4 with stainless intake valves and inco exhaust valves with a custom cam) 24x and 1x reluctors on it just because of what it can do for rev limiters and ETC control without a TAC module over using a 411 PCM. I have a bunch of spare 411 PCM's kicking around, but I went out of my way to get an E40 for that build...since it's an engine swap into a 1995 OBD1 car, I can use just about anything I want so long as the hardware is compatible. E40 for the win there too :)
:banghead: I made a thread on this at one point in time lol.
I went ahead and quoted the switchover delay in your thread MikeOD
Do not try to use Spark ONLY on a E40... it doesn't work lol. You need to keep Fuel cut enabled on a E40. We hit 8192+rpm twice on a procharged GTO last year from a mis shift with no limiter.
The RPM Hyst. is the amount of rpm below the set limit for the cutting routine to re-enable. Ex: Limit set 7000rpm, RPM Hyst. set 200rpm, when the engine reaches 7000rpm it will use the method of cut you have enabled (E40 is fuel or ETC only) and the engine will have to fall 200rpm to 6800rpm before the method of cut is re-enabled. The lower you set the RPM Hyst. number the quicker the limiter is. I usually try not to go below 10rpm just for error.
NLS help needed.
Has anyone experienced this problem or does anyone know what could be causing it.
I tuned in the NLS into my E38, 2010 Camaro. The launch and shift limiter worked fine on the street after testing it. I then went to the track to try it out. I used my line lock to heat up the tires then pulled to the line and launched the car off the limiter (4500 rpm). The car launched then bogged due to limiter kicking in all around the 4000-4500 rpm area. This occured through first gear and a little hestitation in second. My clutch did not stick to the floor nor was I experiencing engine or fuel problems. The problem occured each run for a total of three times. I did not have my computer to troubleshoot at track, my mistake. As i said it never happened on the street.
Sorry I was not data logging which could have helped out pin pointing the problem. I am cutting fuel and spark since i do have cats on the car.
different tires?
No same tires i use on street nto5r. The car does hook at the track unlike the street.
sorry i should have explained that the car did not bog because of the tires or to much traction. it all happens as soon as the limiter kicks in just after launch.
one bad '010, can you post up your cars file and I'll compare your limiter stuff to my 2010 Camaro stuff? I had no issues with it at the track yesterday.
will do i have to get it from my lap top just be a second.
sorry took a while
bump your cutoff rpm hyst to 25,
extreme cutoff needs to be higher than resume, so make that 6500
extremem resume is good at 6420
cutoff rpm vs gear
should be 100 below your extreme cutoff, so 6400 is good, you should make the 4,5,6th gear 6400 as well
i have spark enabled al fuel cut and etc disabled
rpm limit method delay vs gear, i use 10 for all cells
see if that helps any.
-Carl
Thanks will do, now if only this rain would just go away. I will update you when the ground drys out so I can test.
I agree with what Carl said for what to change...and I have the same dilemma here...rain, can't play :(
MIkeOD
Thanks for following up. I don't post often so I had a little trouble posting the tune file. You guys on the forum are great taking time to help out us newbees.
check this later
Justin I think I'm going to try this (though it will be a major re-learn for me to not lift on shifts, I've trained my feet to lift, albeit quickly, for decades now).
Can you post up your latest tune that has it working well? The one attached to this thread I think is one of your trials and I don't think it worked (the switchover is zero in the attached tune).
I'd appreciate it as would others I think.:cheers:
Would a bungie cord or bunch of rubber bands connected to the clutch pedal help increase your ET? Or at minimum, help the pedal not returning problem? Sounds like the GM engineers realized when the pressure plate gets hot, it gets weaker, or some pressure builds up in the hydraulics, but in the end forgot to add in the force required to push the clutch pedal back... hahah. Opps.
I also wonder if this no lift shift is a way to help reduce the pressure spikes associated with these types of blowers when closing throttle completely then re-opening it at WOT/5000rpm shifting in boosted manual trans cars.
