I can respect it, I was just wondering if it could be done, and I figure if anyone knew it would be you. I'll let my customer know and see what he wants to do.
Will this work for the 68rfe?
I can tell you haven?t really read this thread because I clearly stated on the last page that I run full locked upshifts on my 68RFE. So yes, it can be done.
Sorry Jim I did read the thread. I meant to quote the write up from Chad Pope on the first page. I just installed a revmax zero flex VB in my truck. Want ramp up line pressure and make shifts crisper and not lug maybe stretch out the gesrs a bit longer, make it act like it’s in tow/haul without the downshifts. I have an 07.5-09 truck, as I understand it these are more difficult to tune? I also have Anarchy EFI tunes on the truck. I’d like to not have to change them. Just want to use HP tuners to tune the trans and then maybe down the road after I take a course or 2 and do some serious reading I’ll jump into the ecm side of things.
I’m also a FNG. So please bear with me.
Tyler
Honestly the so called guide in this thread isn?t very good, not really right and not worth applying, especially to a 68RFE. Really there is a bunch of parameters missing to properly dial in the RFE transmission. The 07.5-09 68RFE is more difficult to get tuned, it?s quite unorthodox compared to 2010+.
No clue what FNG is.
Yes locked upshifts are possible for your model year.
Great read. I have 65rfe with 2700 stall. HRT stage 2 cam and a few other things. I understand more now and feel better about toying with it. Jeep has been running and driving 3 weeks now but I have been taking it easy so I don't kill converter. I have engine side tune safe and idles well /I will update after playing some
Also interested in paying to get a tune on trans side.
In the VCM Editor, when editing upshift and downshift profiles, both the X coordinate (trottle %) and the Y coordeinates (rpm values themselves) can be edited. I am curious, is changing the X coordinates (trottle %) is OK with the transmission controller?
I've changed them in my tune, the VCM Editor saves them, writes them to the PCM/TCM, the vehicle moves, but I need to be sure if the controller reads them and interprets them correctly.
I also saw several stock tunes from the repository for different vehicle models with the same 45/545/65rfe transmission with slightly different X cootrdinates.
One more question - does anybody know what exactly TCC unlock, unlock to partial, partial to full, full to partial means?
For example if the TCC is in full lock, how "Full to partial" threshold makes it go out ot full lock? The threshold is in rpm, and i suspect it is a difference between something, or a speed of something, but what exactly?
I look at it as the screwing part
kinda pregnant
TCC unlock means TCC unlock, TCC unlock to partial means TCC unlock to partial lock, etc etc etc. not really sure what you are getting at here. The TCC has 3 states it can be in, unlocked, partially locked and full locked and it needs set points to tell it when to move between the different states. The speed in the TCC tables uses turbine speed, it’s not an offset or a delta or a something, it’s turbine speed.
Understood.
And another question - Torque Management can be disabled from "Engine" section, and from "Transmission" section.
If it is disabled in "Engine" section, but not disabled in "Transmission" section, could this cause problems? For example, TCM with enabled torque management sends the needed signals and expects something to happen, but nothing happens because the ECM with disabled TM won't allow it to happen?
One more question about TCC set points - "Unlock to Partial Lock" and "Partial to Full Lock" are obvious - it will switch to the state when the RPM for a given trottle % is above the value of the table, but how about the "Full to partial" and "Unlock" thresholds? It will go to these modes if RPM are below, or above the value.
Here's what I want to achieve - with stock tune, on 3-rd (direct) gear, the TCC goes to partial lock relatively easy, but almost never goes to full lock. I made it go to full lock more easily, making unlock to partial lock and partial to full lock tables more or less similar to these for 4-th gear, but now it "sticks" to 3-rd in locked state too much for my taste - I have to push the pedal pretty far down in order to get it out of full lock. What can I do to make this needed push smaller? Can it be done by altering "Full to partial" and "Unlock" tables? Should I increase or decrease the values there?
Yes pressures can be increased for the 07.5-09 68RFE with HP Tuners. It is missing lockup pressure gain for it though.
Only a fraction of parameters are available without custom mapping but the basics are there
