Originally Posted by
gmtech16450yz
Ahhh, This is when the student becomes the master! Ha Ha.
The biggest problem for most people is cam timing cannot fully be assessed on a dyno. Most stock tunes at idle and full throttle the cam timing is pretty good, not much room for improvement. The big (sometimes huge) difference you can make on changing cam timing is drivability. Again, I'm new to LNF tuning, but on gen 3 and 4 V8's if it doesn't have an actual EGR valve, they'll use cam timing to reduce NOx and lower cylinder temps. If you remove the cam retard in the center of a gen 4 cam timing table, you will get WAY better response in the midrange. Idle and full throttle will be the same, as will full throttle hp and torque on a dyno. I've had some very well known tuners tell me there's nothing to be gained by changing cam timing (again, I don't know yet about LNF's, I'm talking V8's and V6's) because they get too wound up in dyno readings and don't realize most street driving isn't at full throttle but between 1/4 and 1/2 throttle and 1500 to 3000 rpms. That's why guys like you 3 (and others) that are mostly messing with their own cars and have hundreds of hours logging changes a lot of times know more than the pro's on their particular engine.
I'm still going to try messing around with the cam tables, but mostly in the middle, not full throttle or idle. With the amount of KR these little motors produce, you guys are probably right, there's not much more you can get with cam timing without raising cylinder pressures too high.
