General Motors Volumetric Efficiency.
If anyone is struggling with the formula(s) here is a cheat sheet to put it together for you.
Edit:
5 Nov 2021, version 2 sheet attached. If you've successfully used revision 1 there is no change to the formulas it spits out. Just made it easier for guys who hate long math parameters to get up and running.
This is for the E38 correct? My issue is trying to convert these to values for an E67. There are a few choices in the E67 for these different values that I don't know which will work. Trial and error on my part I suppose. If I figure it out, I will post my formula here for the E67 guys wanting to try this.
Thank you for the chart.
It is for both. The numbers in there are for my E67.
Sorry Smoke, I wasn't intending to side step your much deserved credit for the thread. My inability to understand what was wrong was from my own inexperience with tuning. I'm still showing some highlighted PIDS in the math so I need to find it whats going on. Attachment 113993Attachment 113994
oh no you don't lol. I'm just the spreadsheet guy.
For any red parameter, click on it in the formula and follow the steps attached to get it to suit your vehicle.
Notes:
Clicking the gear icon in step 4 is very important as it restricts the channel choice to those that you are logging.
The parameter unit must match those already outlined by smokeshows formula in post #1.
After using it for a few months this will start to happen. Nice overlayed lines.
That’s friggin beautiful. I’m not there yet. Assuming this is just steady state in one gear.
Auto with a high stall that is unlocked until 6th. Manual will be much harder for sure. Here is another example of what we need to try and achieve. Accelerating through the gears, this snippet is 60 to 90km/h at a constant 40% throttle. Only the closed loop filter is active so open loop GMVE is ignored in my histogram. Also note that the gear shift is ignored for some time either side to allow things to settle again.
A good tip given to me by 07GTS is to put your filters into a math parameter and plot them so you can see when they are active or not. Its a bit more maintenance when making filter tweaks as you have to keep them in sync across math parameter and histograms but it's worth it once they're all dialled in as you can have a lot of confidence in the data you are capturing.
Closed loop filter
[2517.161.avg(1500)]=0 and [2517.161.avg(-200)]=0 and (abs([50090.156.slope(1500)])+abs([50090.156.slope(-500)]))<2 and ([6310]=9 OR [6310]=14 OR [6310]=15)=0
Open loop filter
[2517.161.avg(200)]=0 and [2517.161.avg(-200)]=0 and (abs([50090.156.slope(250)])+abs([50090.156.slope(-250)]))<2 and [6310.avg(250)]=9
Great.
Probably should have added instructions so I'll add them here.
Find out what the IDs are that you are logging for these parameters:
- Mass Airflow
- STFT Bank 1
- LTFT Bank 1 (Optional depending on tune config)
- STFT Bank 2
- LTFT Bank 2 (Optional depending on tune config)
- Wideband Bank 1
- Wideband Bank 2 (Optional)
- EQ Ratio Cmd
- Engine Speed
- Intake Manifold Absolute Pressure
- Volumetric Efficiency
- Manifold Air Temp
Head across to the spreadsheet and plug your IDs into the blue ID column.
Copy smokeshows formula(s) back into your math parameter(s)
The use of average is optional. I use an average of 200 for closed loop in all my logs as it seems to line up the GMVE data with the O2 sensor swings nicely. For open loop I do not use average. Play around with it to suit your own tastes.
