yayyy
yayyy
Just so everyone is clear - you can data log with the Stable build on a V3 so long as you re-poll for parameters after connecting to the ECU and using the configs found on post #35. I have not tried adding my wideband into the mix yet but am hopeful it logs fine. I?m assuming I will have to bounce back and forth between the stable build to datalog the car and then tune/flash the car with the beta build.
Got a good data log. Just to confirm for everyone doing this, to do the flash, I need to use the beta builds correct? Stable still has flash issues with JTEC right ?
97 Jeep Grand Cherokee 4.0l JTEC. VCM Scanner works for me after using layout on post 35 and repolling with stable version.
How do you interpret the Spark Advance histogram? I understand the LTFT, mine is -15% so I would try to get that as close to 0 as possible by multiplying the tune fuel table by .90. But if you have a value of 17 in your spark advance, how do you interpret that to change your spark table?
00 Dakota R/T, 5.9L/46RE, JTEC+
MPVI3 and the latest BETA works for writing to my PCM. Used Stable for reading the tune and datalogging no problem. Read the stock tune and all 3 Superchips tunes successfully, then flashed the superchips tune back with the MPVI3.
Does the Superchip tunes change any of the transmission programing?
