Come-on' now fellars,...I didn't mean to stir up trouble,....I'm simply trying to learn as much of the ins-and-outs as I possibly can (string it all together in my own head,.... which is tough for my older ass sometimes),...and maybe someone in the future can see the issues with the old trans/how it was tested/and initial new trans startup observations with subsequent dumb questions,.... with all y'all's expertise on "how-to/answers". I'm definitely not a tuner,...only been at it for 6 months, yet, you guys have taught me tons in a short period of time. Big thanks to all you guys.
Yes I'm guilty of being analytical,...I'm a Senior Project Manager that's overall responsible for new Power Station Construction, Commissioning (Startup), Validation Testing and Turnover to end Client,...thus, I guess my mind works that way,....wanna know all the fine details,... I don't have a college education,...I worked my way, up through the field, to the most senior level,....And yes, you can put FLT's transmissions in a Space Shuttle:):D,...they are that good. I must say, I got a chuckle when I read that one.
JasonB, you've helped me in the past bud, and I respect your experience (as well as all you guys). I know you didn't read the entire post (I know it's long bud), but,....the past few day's nut is - I finally got the new FLT trans installed,...and on the first two test drives, the internal trans clutches felt like they weren't grabbing as hard as "I thought" they should be.
Shifts fine, and right on time per my shift MPH/TPS tables,....and TCC locks perfectly on time too (hard). Yet seems like my engine rpm's (as truck goes up through each gear) doesn't reflect the "grab-er-and-growl" the rear end should be layin-down'. I know it's not the FLT trans, I can assure people of that,... thus, I started looking at the tune/adjustments,...and subsequently (and apparently, asking dumb) questions.
Thanks for pointing me towards the 02 Silverado pressure reviews,...I'll look into that tonight. And, Yes Sir, I put a new torque converter in it (per Chuck - from Precision of New Hampton - with an Allison hub and weld reinforced - stock stall speed). I also disabled the old (yet still new) radiator cooler and removed the extra stock cooler, with all the lines,... and then installed a new 40k Tru-Cool cooler with all new -6AN lines/fittings,...because I knew the old (yet still new) trans had contaminated the entire cooling system with clutch/metal debris.
I hear you on the 100 miles before I adjust anything,...that was my plans. But, figured I'd ask the "holding power" question above, before I started scorching new clutches,...in case it was something stupid I'd done,...and someone could say, "hey Newbie, you got this wrong!",.... which wouldn't surprise me.
Apologies again guys,... for being perhaps overly cautious with this,...it's not the money,.... it's the "man, I don't want to go through changing this trans again,...already did it twice,...a third time, and I'd be ready to bite 10" I-beams in half!!!" It's a hot mofo down here in Florida right now, and I'm doing this work in my driveway with no shade,.....I know, I know,...gotta be tough when your dumb (like me). Apologies again guys.
On another note,..something interesting I found today though,.... My "Normal Shift" table 2D chart looked a little off,...meaning, the 3->2 downshift curve should be above the 1->2 upshift curve. And the 4->3 downshift curve should be above the 2->3 upshift curve,...... (I know this ain't got nothin to do with the above). Did y'all know you can move the dots on the curve of the 2D graph, and it'll change the chart numbers above??? I found this by accident today, and thought, man that's fairly cool. Anyway, I moved the dot/curves around so both downshift curves are now right,....didn't have to move them much, just a few mph adjustment. Now my BluCats inspired 2D shift point chart looks awesome. I'll upload this simple adjustment tomorrow and see how she acts.
