Makes sense.
Makes sense.
VCM Scanner version #397
Innovate MTX-L: Works
upon further testing it works fine but if i stop and restart the log the wideband will not log anymore. I have to close and reopen the program to get it to work again. This happens every time.
One question to everyone. Are you using the serial output of your LM-1/2 or the USB output. I ask because the USB output uses the SP2 serial protocol and I believe that is what is being implemented. I don't have a vehicle to test it on atm but I plan to in the coming week. I might just go out to my DD and leave the LM-2 in free air to see if I get any reading over the USB interface. I'm hoping I do. :)
I'd get dr.mike to re-flash it for you then just run it over the CAN bus. Then it's faster than 0-5V or serial.
And? Pretty sure those vehicles have an OBD port.
So I could wire it into device OBD adapter and not have to wire it into each car I'm logging?
Can be wired to one of these so you can just plug it into OBD port then plug HPT into it
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The only problem I can think of is on pre CAN vehicles you have to add a resistor and CAN vehicles don't need that.. so that'd be something that would change depending on vehicle
I'm waiting on my new WB to get here. Should be hereTuesday.
I have innovate LC-2
it is working!
This is what I'm running. The voltage reading at the end of my male/female connector is right in line with the stated chart. Still trying to figure out how to get it to communicate with scanner. I'm using a DB9 to USB converter. My laptop recognizes the port and converter, but I've got nothing in the scanner. I'll post an update once it's figured out. Hoping to add another Wide-band option to the mix.
http://prosportgauges.com/wideband-a...ratio-kit.aspx
http://prosportgauges.com/instructio...alwideband.pdf
Any progress on the ECM AFM1500?
Can zeitronix zt2 serial support please be added.
Ben
This should help :)
Attachment 60228
Could serial support for Techedge 2J2/9 be added please. Links below have alot of info not sure if the protocol info is in there as I don't know what I'm looking for. I will contact Techedge to ask them directly for protocol info. I have sent a request to HPTuners support also.
http://wbo2.com/2j/default.htm
http://wbo2.com/sw/logtech.htm
VCM Scanner version: 3.2.24
Innovate LC-2 with Bosch 4.2 Sensor: Works great!
