Good to hear!
Good to hear!
Here is a pic of my setup.
Attachment 57960
Nice!
OK everyone. This is last call for AEM 30-0300 and 30-0310 beta re-flashes.
I will stop doing the re-flashes after next week.
So far, everything looks to have gone great with them.
Is this something you think AEM will take on themselves for their product line? This is an incredible capability, and I'd hate to see it end here.
I'm pretty sure somebody will take it from here. :)
I went with a slightly less elegant solution of a y-splitter and a right angle extension since the OBD2 connector in my car puts the cable directly in line with the clutch...still tidying up the vehicle side of things, but overall I'm pretty pleased with how it turned out.
http://i305.photobucket.com/albums/n...pscnbopnxv.jpg
I'm interested in whether it worked with dash logic or not too. I got them to add 4 different PID's, they thought at least one would work. Did you try all of them? Did someone send you the firmware update I assume?
They got the other issue fixed now
I sent you a PM Dr. Mike
I have version 2.02/2.2. The firmware download says 2.02, but the version # on configuration utility and on the DIC says it is 2.2. Nevertheless, I tried the 4 PID's they have loaded, 32, 33 34 & 35. All show a reading of 0.0.Quote:
Description of PID's - Actual Lambda Bank PID 24 & 34 - Actual AFR Bank PID 24 & 34
I assume it shows up in HPT correctly over CAN bus?
Yes
Attachment 58176
Your PM Inbox says you've reached your quota, mine is on its way to you Mike. I appreciate it.
Ok. I cleaned u some messages. PM should work now.
kk5zc, it looks like you have the poling rate set slow for the WB ?
Thanks to everyone who helped out with the beta testing on the AEM OBDII firmware upgrade.
I am wrapping things up, now.
Everything looks good to go. Hopefully, someone will pick the product up soon. :)
