post your modded tables
Here are mine. Not sure what boost this gives me yet though, since I haven't loaded the tune on the car.
oh i get it now awesome im poundin 30 for the dyno and 26 for the street if i can 8D
what do i send support to get this again i fergot
after all my head work i could redline to like 9k 8D
Send them the S/n and your customer number I believe. Make it titled as bosch overboost beta.
I know this is the wrong place, but can someone post up a quick screen shot, or tell me what i need in my table to log boost and WB in the scanner? I had it set up, and a file corrupted and i lost it all, and now i cannot find half of what I had in my table.
Yeah, i realized that just now, lol. This allows us to up the DAL's more, right?
BTW... I am having a ton of trouble with the scanner right now. Seems like I am missing half the parameters I need to run a config file i have made up.
very nice, can't wait to play with this tonight. My friend with the gt3076r 09 is gonna be happy.
will also be testing tonight.
I will set the over/under boost test to 8k on a stock tune. then I will install my aem true boost boost controller again and do all my boost adjustments via the controller rather than changing the dal tables. the reason I will try this is because no matter what I do to the dal tables I will always see between 20-22psi. I am hoping that the aem controller will keep everything closed (wastegate) until I want it to open. if it does with no problems then I need to figure out why my boost sol. will not stay closed. any ideas?
I hope I am not to late I sent my email to support.
u should use the factory solenoid to control that. i would
this reading is from a digital aem gauge off the manifold. boost will not increase above 20-22psi nor will my maf read more than 33lbs/min even at 320 dal's. a dejon sri is on the car. I may put the stock air box on to see if there is a change. I may start a new thread about this concern because it seems like multiple people have this problem.
yeah we had that problem with the stock boost control on the big turbo too.
Only issue I'm still having was the underboost/overboost crap
yeah using a 2 stage MBC.
I use a dejon mbc to control my boost, works fine.
Log your VE airflow. The MAF flow can be 36-37 lbs/min on the stock turbo but I have yet to see a log where there was more than 30 lbs/min VE airflow on the stock turbo. I have seen logs were MAF flow was 38 lbs/min but VE airflow was 28.6 lbs/min. My car sees 33-34 lbs/min MAF flow and 30 lbs/min VE airflow. MAF flow is skewed by intakes. Look at the VE airflow. :D
