Originally Posted by
Hutchinson
Well guys, got all my test tunes set up to run. Gonna upload first tune listed below, then drive, then upload next tune, then drive,...etc. all the while scanning for desired results on how those changes affected drivability/performance. Each tune "step" below will have all the previously made changes included, thus, I can tell how they work/interact,....individually, and as I go through them all (accumulative). i.e. 6.6 will have all the changes made from 6.5, 6.4, and 6.3
I decided to address the Spark Retard first, then main shift tables, then pressure multipliers/modifiers.
Tune #
6.3 - Zeroed Trans TM and Abuse Tables - has no transmission TM
6.4 - Engine side of TM - Zeroed Spark Retard vs Torque Reduction table
6.5 - Zeroed both Normal and Performance Shift Time Tables - Desired Shift Time vs Torque Tables
6.6 - Adjusted Upshift Line Pressure Normal and Performance tables - 90psi from 240TQ up, and then interpolated between horizontal lines between 0-240TQ
6.7 - Zeroed Upshift Pressure Multiplier Table
6.8 - Zeroed Upshift Pressure Modifier 1>2, 2>3, 3>4 tables
Per 6.7 above - Should the Trans>Auto Shift Properties>Shift Pressure>Shift Pressure Modifier>Pressure Multiplier table be set to "1" in all table cells, instead of zero? Reason I ask, last part of the table description says Increasing the Multiplier firms the shift. 1 = No Change.
Do the above steps in tune changes make sense? Or should I do one, before I do another?
Almost seems like I'm taking this 4L60e back to the stone age,......:cool:
Thanks Fellars
