bluetooth still not working
Quote:
Originally Posted by
Bill@HPTuners
Connecting via BT really couldn't be any more simple.
1. Plug the interface into your pc/laptop using the supplied c-usb cable
2. On windows 10 click the search icon and type in settings or bluetooth to bring up your bluetooth settings window
3. turn bluetooth to the on position
4. Hold down the button marked BT for 5 sections to enter pairing mode
5. select + Add Bluetooth or other device
6. select HP Tuners MPVI2 in the pairing window
7. done.
I've tested this on multiple pc's today and its worked flawlessly on each.
Why is the c-usb cable required when doing bluetooth? If step 1 is omitted, should we expect bluetooth connection issues? For me, it will pair and go into 'connected' state. Then it quickly goes back into disconnected stats. The crazy thing is this was working fine on my Windows laptop a few weeks ago. Nothing has changed and now it doesn't connect. Granted, I haven't tried using the c-usb cable. It just seems unusual to require a c-usb cable for bluetooth. Bluetooth is intended to be used over wireless.
