that does not matter
post the answers anyways : )
what does tazer see for tire diameter?
what does scanner see for tire diameter?
what does scanner see for gear ratio?
what is the actual (measured) rollout of your rear tire?
what gear is in the car?
28.18"
26.35"
3.42:1
90.7"
3.70:1
mine ^^^
I was telling you i was told it made no difference, and that even with factory gear and tire, it still had the same issue. but i did change thegear and tire size in the scanner. Gear is 3.70 and tire is 28.8. As for the tazer im not sure what it reads, i dont know how to check
1 Attachment(s)
here
what value does it see for tire diameter?
